Enduro Racer brake and accelerator issues
BroWoah
Alabama
Hello, my Enduro Racer is finally up and running using a Smartypi replacement pcb. Everything is running perfectly (audio, graphics, steering, up and down) except for the accelerator and brake. Currently the game is unplayable because the brake is always active and you can't accelerate.
when in the diagnostic menu the brake and accelerator only move when you turn the handlebars. When I removed the control unit it was still not working. Once I removed the connector from the board, the brake was no longer active and it was accelerating automatically. If anyone knows what the issue is or has a picture of their connector that would help.
In the attached picture you can see that the connector to the board is damaged. I'm unsure if wires were also damaged. There are 3 wires: red green and brown. I'm not sure where these go and if these are related to the problem. That white wire also needs to be fixed.
Here is a video:
The crt monitor is currently being fixed (don't go crazy over the lcd) it just needs to be playable for now.
