willymotts
This is my first foray into pins. I just picked up an Embryon and it won't coin up. Playfield and back lights work and all fuses meter out ok. Where do I go from here, please. Thanks.
No displays as it just blows the fuse. I ordered the 35 amp/400 volt bridge rectifier from Bob Roberts today. I'll give that $3 fix a try first!
I was getting all sorts of incorrect voltages on the rectifier board. I ordered a replacement from Marco. Stay tuned...
There is a short flash at the initial power from the switch. Then, there are two "real" flashes.
You probably have a bad 5101 RAM or socket:
http://www.pinrepair.com/bally/index2.htm#flash
Is there any corrosion on the board?
