EM weighted tilt switch
Spbeyond
Utah
Hey guys, on the bottom board of my EM pinball there is a tilt switch with a weight on the end and a screw underneath. Anyone know if that is supposed to be normally open or normally closed? Thanks
I would assume it would be a "slam switch" that should be normally open.
It should be open and if it makes contact it will tilt. You can adjust it to be as sensative as you like.
Glennon
which way causes the tilt relay to pull in.....adjust accordingly.
