Elevator Action to Alpine Ski.
caddysrule
Tracy, California
Hello,
Elevator Action was a conversion from Alpine Ski.I got a set of roms and a Elevator Action board.Can some one tell me how to make my Elevator Action board into a Alpine Ski?
Jeff
Plug in the EPROMs.
Elevator Action has some security board, but Alpine Ski does not use it. Leaving it in place should not affect Alpine Ski. Layer PROM is the same, so you're good there.
There are two basic types of boardsets for this series of games. One primarily uses 2732 EPROMs while the other uses primarily 2764s. Plug it up. Hopefully you burned the correct set for your hardware.
You'll have to rotate the monitor. Beware, your monitor frame may now extend past the rear door, not allowing you to close it. Put your bezel glass in a safe place. The plastic monitor surround for a horizontal game is not centered, so you can't rotate that for use in a vertical game.
Otherwise, you're good.
Let me know if you have issues with the ROM placement.
Kerry
