Elevator Action internal wiring
Portent
Victoria, BC, Canada
Hello,
Can somebody post pictures of the internal wiring of an elevator action that has been modified with a new power supply? The previous owner did some interesting splicing and it doesn't match the original specs so I was hoping somebody else had pics of how it was to be plugged into the PCB with the new config.
Thanks in advance
somewhere ive got a pic but im goingg to have to do some digging.
also fyi mine would not run with a switcher unless the white reset wires were removes from the filter board.
edit: here it is.. unfortunately its looking like its way overexposed.
the wiring might follow standard wire codes blk= gnd etc
Do you have the interface board? There is an invert circuit for the Reset line. Make sure the reset is connected.. Cant remember off hand if it goes to +5 or 0v. I had a problem with it in a Jungle Hunt cab I repaired.
