Do you have any other monitors near this? A monitor shimmy can be caused by nearby monitors, or High Tension lines.
We had to put makeshift faraday cages around some monitors under 345 kV lines to eliminate this shimmy.
Note: The power supply ripple is more likely the culprit. This introduces other things that could influence the behavior, but likely aren't the cause.
