Electrohome G07 only 1/2 the screen showing
anthonystich
Hellertown, Pennsylvania
I had just purchased a new/used chassis for my electrohome G07, no matter what I do or how I adjust it I am only getting the top half of the game on the bottom of the monitor , I am using it horizontally , the picture and colors look good , but only 1/2. I am at a loss???
One other thing, take a good look at the solder side of the board where your video cable hooks up. If there are any halo rings around those 9 pins, reflow em with your solder gun.
re:
this is a dedicated board , i had an extra pcb that was also dedicated Buster Bros but I assume the suicide battery killed that , so I only have the one pictured at this time to test, I checked the Sync, the sync upgrade , The B+ is at exactly 120V
What does the vertical hold do for it ? (can you roll it up into the upper half of the screen)
Is the vertical centering jumper in place ?
