mike11
I got a ms pac for a resto project...... Has a G07 in it with the tube neck broken. I have a k4900 here with good tube but needs power transistor.... I swapped the chassis along with coil n purity rings ..... Fire it up with a known good board and this is what I see..... I tried an 8 liner board on it which is for a horiz monitor not vertical not sure if that would matter here for testing purposes......... I don't know the history of the pac board or if there's issues with it or not....... Ill pass that brindle when I have a known good monitor for it.... I have a good WG 7000 also , when the pac board is hooked to that I have nothing ....... Anyway thoughts and opinions on this G07 please.... Is the 4900!tube usable with a G07 chasis ???
Thanks guys you always bail me out
