You should try replacing or testing the transistor at X303 as well. I've seen 'em short before causing similar results. Worth a try anyway.
Can that be tested in place? I think I need to pull it to get correct readings right? I actually looked for the part locally but couldn't find it. Fry's Electronics said it's been discontinued which doesn't sound right. I tried a couple places. Everyone has NTE290 but not NTE290A which is what it cross references as.
The reason I didn't spend more time checking that would fall into the "two unrelated problems at once" category. Which is far less likely than me just screwing up something in my original "repair".
