Electrohome G07 issue......
Swillie
Michigan
Hello. In short when cold the screen looks crazy, vertical lines scrolling left to right very fast.... after a couple minutes the screen starts to straighten but with curling on the right side.... after about ten minutes or more the curling straightens out finally. I did a cap kit from LizardLick a few years ago (NOT the flyback or HOT, just replaced the caps), which improved the picture if I remember but never solved the warm up problem. Recently the curling would never straighten out at all...I just checked the B+, it was 109V, so I adjusted that to 120V. Than I adjusted the V-hold and V-lin pots and now it straightens out perfect, but still only after it is warmed up.
Any ideas???? Is there a proper technique for adjustment to those pots, or are there ones that I am missing???? when it comes to setting those I feel like I don't really know what I am doing, just trial and error. The flyback is dirty but looks intact, no cracks that I can see.
Not sure if it matters, but the cabinet looks to have been a Stern Scramble which was converted to a Taito Big Event Golf.
Thanks for any help. Steve
If you did a standard kit, not all caps were replaced. It's possible that one of them is "on the cusp" as it were.
Did you reflow solder? I redo the entire neckboard, power supply and any other suspect joint on any rebuild.
Just a standard cap-kit. I don't recall if I reflowed the solder at the video header pins that i have read about, don't think I knew about that at the time. I was going to check them but thought i would gather as much info as possible before I pull the board. I just checked and the horizontal width coil is ascew a bit and no adjustment knob on it. I read up on Bob Roberts site about how to adjust/center a monitor and I think one thing throwing me off was that the monitor is turned vertical, so the vertical lin/height adjusts horizontal(left/right) for this perspective. There is a <inch gap at top and bottom which i can't adjust because of the missing knob on the h-width coil, right? So I centered and widened the screen nicely and than carefully put the v-hold and h-sync pots thru a full range of motion and than adjusted them back and forth a bit , putting h-sync closer to the 3 oclock position( read that somewhere) and the picture is holding steady with very minimal curl along the side (which really is the top). I powered down and up after 10 minutes and it came back pretty straight and warmed up within a minute. I have to go to work, when iI get home I will see what happens. Can't believe it has just been out of adjustment all this time but I just couldn't get it right before.
I am fighting the urge to pull the board anyway and replace the h-width coil, flyback and HOT , than reflow solder to finish what I started, but i hate to break something else in the process when overall it is looking very good.........
Looks good as soon as you power it up now. Just can't let go of my old golf game.
