TokensArcade
Got an Electrohome g07 all recapped and tuned up. Reinstalled it in a Ms Pacman only to find out the plastic casing of the horizontal width coil seems too have crumbled and finally cracked, The top part of the plastic casing as well as the screw that you adjust have come completely off. Strangely though the coil itself is still working. The monitor looks absolutely fine and I have no problem with the positioning. I was able to get it where I want it and am otherwise satisfied. The question I have is whether or not there is any issues beyond just not being able to adjust the width with the casing of the coil broke. Anything potentially harmful to the monitor? Like I said it looks perfectly fine as-is. Should I replace it immediately and not use the monitor in the meantime, or am I fine for the time being?
