Electrohome G05-802 Yoke Resistance and Monitor Help
Can anyone help me out with what the resistance readings should be on my G05-802 yoke? I've been battling with the monitor in my Asteroids Deluxe for months now (blows fuses and transistors), and have narrowed it down to either the tube or the yoke. The tube tests bad on the cutoff test (according to my Sencore CR70), but passes everything else. I'm not quite sure what to do. I have searched high and low, but haven't been able to find what the yoke readings should be.
The reason I have narrowed my problem down to the tube or yoke is because I have tested literally every component on this chassis and replaced all of the recommended parts. I even sent the chassis off to PNL Video and they said it worked perfectly for them. I have also read through the B&W XY FAQ several times and studied many of the G05 repair threads here on KLOV. Maybe I'm missing something really obscure, otherwise it has to be my yoke or tube. Any thoughts?
P.S. I also bought a working chassis off ebay a while back. It worked for about half an hour and then R100 and R101 were super hot and several small resistors burned. At that point I checked the voltages coming from the power supply and they're fine. I'm ready to pull my hair out
. Thanks in advance to anyone that can help me out!
