csa3d
Elecrohome G05-805: Small fire on Deflection Board
So today I performed the R100/R101 wire mod and game my G05-805 a test run, now that I have recieved working and verified game PCBs for my Asteroids cocktail. I also reflowed all the pins which looked like they could have had loose solder joints.
When I gave everything juice, I neglected to first plug in the anode cap to the monitor. This resulted in a small fire on the HV board.
While I am kicking myself for this mistake, it brings about a few questions as well. Before the questions, here's what parts appear to have been affected going only off visuals:
Questions:
1.) What's the repercussions of not having the annode cap hooked to the monitor and giving it juice? Would this have been the sole cause of everything going wrong here or was this a situation where It would have no affect, and I was just lucky it wasn't shorting out on the monitor frame or something other.
2.) I'll assume it's plausible that the anode cap had no effect, and the parts which were burned weren't going to work anyways. Is it as simple as cleaning up the damage, replacing the parts, then give it another go?
3.) What now? Any other suggestions other then replacing parts and giving it another go?
Thanks all. I guess if this was easy it wouldn't be fun... stupid asteroids..
-csa
- 2amp FB fuse at F700 blown
- Small fire around the center most big 6800uF Cap
*note: These caps have both have been replaced with a kit from Bob Roberts prior to this incident *- two pinholes around base of said cap at C101
- R713 fried
- R718 fried
- R705 has possible damage due to residual damage
-csa
