EDOT Mirrored inside walls- source?
khabbi
Tampa, Florida
Now that the weather is nice here in Florida, I'm working on getting my EDOT restored and into my arcade. There's a few things I want to replace or dress up, and this is the first thing that I'm going to try and replace... the sides are pretty scraped up from the control panel being lifted, so I'm hoping someone here has already replaced theirs and can help with finding a source for this.
Any ideas? Thanks in advance!
I need the same thing. I was thinking I could cut new ones, if I could figure out the exact material.
I'm sure local glass shop could cut you some new ones? Might be a little pricey though??
Well it's not glass, and it's very thin material. Just looking for ideas.
When searching I found where holokid had taken some thin plexiglass, cut it out, and then took it to a tint shop and had them put mirrored tint on it, and it turned out good.
Does anyone know if both sides are exact mirrored images of each other? IE, now that I have one side out I could make two copies of it and flip the other side?
I may be able to get these reproduced from the original drawings if there is enough interest. I can look into it if enough people would want them.
Joe
Joe
there are enough people interested
what type of price do you think it would be?
spent about 5min googling this and found a source in Japan that sells adhesive backed mirror stickers. approx 19in x 4ft. THere has to be a source in the US for this.
i bought a door mount mirror at either target or walmart some time back that appears to be something like 1/8" plexi with the back silvered. I'd bet you could use one of those for the mirror if its thin enough.
I have been looking for this material for a while with no luck. I have found thicker material etc - but nothing that is exact... I would very much like to replace mine as well
Pretty sure ProK had this stuff at one time but needed some measurements or a template-IIRC
for those with an inside connection with him you might be able to find out ;)
I just put a call in with the original manufacturer of the material. Hopefully I'll know something later today on cost and minimum volume. It's not something they stock but was special made.
