One thing I have had trouble with before is removing pins from edge connector housings. Even using the right tool made for removing them, I've found it's hit or miss at times at least for me. Anyway, last night I had a wire break off on my Pole Position's edge connector. It was the -sense wire from the video board connector. I had already replaced this housing so I can only assume I didn't do a good enough job with that -sense wire. In removing the pin, I must have somewhat damaged the housing, because when I inserted the new one the pin didn't snap right into place and actually pushed through the bottom of the housing somewhat. It wasn't a big deal to pull it back up into the housing and it's still held in place, but it can be pushed out again with a little force. I was wondering what the opinion is on replacing the housing again. It seems like a minor deal considering the pin is in place and holding fine on its own. Unless I push on the wire the pin won't just fall out the bottom so is it worth replacing the housing again or am I just being too OCD about a minor issue? Thanks for any input.
