When I power up my Secret Service I get the error "Eater Bad"...
But it shows all switches working... and the eater seems to work 1/2 the time. By that I mean it works when the "hideout open" mode is enabled (if I shoot the ball in it drops and recognizes that a ball is there and kicks on multiball mode) but it also seems to stay UP when it shouldn't... during those times (before HIDEOUT OPEN mode) I imagine the hideout should be closed, but it's not... its up... and if I hit a ball in to it, it will drop as usual, but will sit there for 5 or 6 seconds then the system tries to "look" for the ball and starts kicking up things to "find" it and eventually kicks up the hideout letting the ball out.
My hypothesis: Something isn't working right. (HA!) I GUESS there is a solenoid that should pull the eater(hideout) closed that isn't working...
Thoughts?
Thoughts?
