clanggedin
OK... I recently acquired a Toobin that had a bad waterfall motor. I searched everywhere to see if anyone had found a fix or replacement motor for the waterfall. There was a post here I found that talked about the possibility of using an AC gear motor from McMaster-Carr. McMaster-Carr sells a 15.3 RPM gear motor, and they also sell a 20 RPM motor. The Toobin motor is a 16 RPM. I ordered the 15.3 RPM motor because is was closer to the original in speed. When the motor arrived today the rod sticking out of the motor was visibly fatter and shorter than the original. I ended up grindning the sides of the rod until it fit snug into the hole at the end bottom waterfall bar. To prevent the rod from slipping I drilled another hole on the bar closer to the opening that would pass through the motor rod and out the other side of the waterfall bar. I then inserted a screw to make it stay tight together. After that I plugged in the motor and turned on the Toobin.
Total cost of repair was under $25 ($20 for motor , $4.25 for shipping).
Now my Toobin joins the ranks of the others that have a working waterfall.
I hope this helps others in getting their waterfalls fixed.
