Easy Question: Galaxian Conversion class
hindered
Donor 2015
Kalamazoo, Michigan
I'm assuming the games listed as Galaxian conversion classes on KLOV are all compatible with the same wiring harness similar to how all JAMMA cabs are compatible -- is this correct?
In other words, can you swap Pac Man, Ms Pac, and Junior Pac into the same cab with no rewiring?
Obviously, if they were 100% compatible, you'd need to add a button to a Pac Man in order to actually play a Galaga PCB, but the board would just plug in and boot up, right?
Awesome thread, thanks. My search-fu must have sucked cause I didn't find it. Looks pretty straight forward -- pacs are the same at least.
