ThunderBunny
I have a Shinobi board and cabinet but no working monitor. What's the easiest way to hook that up to a regular old TV?
If you have a monitor and it doesn't work, you could probably fix it.
If you don't have a monitor at all, then I guess a tv would work.
http://www.ebay.com/itm/Weiya-CV-04...027?pt=PCC_Video_TV_Cards&hash=item3cbe516ca3
That is just a quick example. I've bought them for around $40 before.
Just wondering here.
So the RGB input comes from the game board and then the composite video output goes to the TV on these boards?
On certain models, yes. But be careful what EGA monitor you have. This adapter states 15.75 as the EGA signal, while other EGA signals are 21.8 kHz.
SPECIFICATIONS:
Power:
DC5V 2A +/- 0.5v
Input Signal:
CGA
15.625 KHz 60Hz
EGA
15.750 KHz 50Hz
Output signal:
Video
CVBS 480p
S-video
Y/C 480p
PAL/NTSC switches, Definition adjust, RGB gains adjust.
