Ease of switching monitor?
Deadpool66
Minnesota
Ended up finding a guy locally whom has some 19in Wells gardner 7203 for 75 some of which dont have burn in. Of course the chance to have non burned screens in my games is tempting Im wondering how hard it would be to install these into my cabinents is it as simple as bolting it down and hooking it up? I dont mean to start so many damn threads just want to make sure I get the experts advice before proceeding.
My cabs are
moon patrol dedicated thats been gutted been thinking about reviving it.
Dynamo cab
and Berserk cabinent
My cabs are
Dynamo cab
Yep, install and hook up. If the power molexes are different, you will have to crimp on a matching set. Then adjust synch and colors if needed. You may also need a degaussing wand. I always hook up outside the cab, specially with horizontal games, to make sure that they work and to make sure that the video is right side up.
Yep, install and hook up. If the power molexes are different, you will have to crimp on a matching set. Then adjust synch and colors if needed. You may also need a degaussing wand. I always hook up outside the cab, specially with horizontal games, to make they work and to make sure the video is right side up.
Sounds good going to buy two hope I can get them today. As far as the molex connectors go which type of crimper and inserts do I need to make one. I bought a few four pin connectors but bought the wrong metal piece that goes inside.
You only need 2 position molexes. They come with the right pins from Bob Roberts or even Radio Shack.
Sweet I had to splice my new jamma harness to make the monitor work and somtimes the screen turns red becuase the connector is not very tight. Learn somthing new everyday.
