Earthshaker switch issue?
Are you using the ball or your finger to activate the switch?
BALL!! Thats the crazy thing. I feel like I'm going insane. Unless I am testing the wrong switch. I'm testing the 'overhead swing arm' (NO idea what its really called) switch thats in the lane for zone 6...But maybe there is another switch that is actually for zone 6. I'll have to look again
I have the same issue with my ES. I find if the ball moves slowly through the zone 6 arch it won't register, but if it goes through at normal speed either backwards or forwards it works fine. I'm almost positive it has to hit at least two gates in succession for it to register. I'll have to look up that switch when I get home, I don't get any switch error on that either.
i have the same issue with my es. I find if the ball moves slowly through the zone 6 arch it won't register, but if it goes through at normal speed either backwards or forwards it works fine. I'm almost positive it has to hit at least two gates in succession for it to register. I'll have to look up that switch when i get home, i don't get any switch error on that either.
thanks!
