Earthshaker Rubber Replacement Map?
jeffsgames
Donor 2011, 2015
Osceola, Indiana
I just ordered a rubber replacement kit from pbresource.com, along with several other parts. I did NOT received a map to show where the rubber parts go and my rubbers are not in good enough shape to match them up. I know several other vendors have guides but PBR does not offer them. Anyone know where I can download one?
And yes, I know I can look at the manual to figure it out. I plan to but I'd rather start with a map to make it easier.
I also have flipper rebuild kits to install, so if you have any guides as reference that would be really helpful as well!
Thanks!
After long searching on Google, I've noticed that this is a common request. I guess I'll have to figure them out on my own!
Sorry I can't help you with your request, but I've suggested in another post that this should be a section in the new pinwiki.com site. A section dedicated to rings kits for all the pins. What a great referance that would be. Maybe, if you document and figure it all out, post it on pinwiki. God knows, you'll probably be asking that same question 5 years from now when you need to do it again.
