Never seen buttons that were screwed into wood....new to me...maybe the threaded the wood and used the regular buttons ?
If you take one out and make a picture of it that would be more clear.
Ditto... I had an early Asteroids cab (with the owl eye coin door) and it had standard buttons, although the metal "nut" was partially covered by the wood backing on the cp. You may have to remove the wood in order to have access to the nuts on the buttons.
Edit:
Yep, just looked at your pic again... just remove the two wing nuts and the entire panel will tilt forward on the lower hinge, then you'll be able to remove the wood backing panel. You'll probably have to disconnect the P1/P2 start buttons also. Then you'll be able to remove the buttons.
