Dynamo Street Fighter II control panel (cut corner)
Teknotoyz
BUFFALO, West Virginia
This is a Dynamo control panel of the Streetfighter variety.
2 joysticks, 6 buttons per player and is 23-5/8" wide from a 25" monitor cabinet.
There is a hole cut in the center where this was a conversion.
Either cover it and use plexi over the whole panel, or make it a nice round hold for a trackball.
I did not clean off the sticky residue from the overlay that was used. A bit of WD40 will do it nicely, I will ship with plastic wrap over it to keep dirt from sticking to it.
$50 shipped anywhere in the US.
Damnit I so needed this!!! Missing from my dedicated 3Koam SF2 CE!!! :(
Don't feel so bad, if it's a 3-Koam K-3 then the panel would be too narrow anyway (23.5" vs. 25.5") and it was the K-3 that Champion Edition was released in, one of three dedicated CE types (HS-10,HS-5, and K-3). You probably need the 25.5" panel.
So- i got the 3Koam waveback, its got a dinky control panel with no side cut so that makes it smaller. The normal CPO graphic for SF2 CE would not fit on here. I have a extra Dynamo side cut panel in my garage but its swiss cheesed to hell and too wide by .25" to fit. I'm going to guess the panel I had is factory, but it looks so gimp! I've seen wavebacks with sidecut panels, I want to make mine look like that as well.
Yes, I see now. I have a 3Koam K-3 withOUT the side cut. Damnit. Thing seems to be dedicatd SF2CE yet.. this control panel overlay could never have fit it. Someone wrote in marker on the inside SF2CE and dated 92 but it has a SSF2 control panel overlay, but.. both CPS 1 and CPS 2 kick harnesses built in. I need the other control panel!
