kazanova225
I've recently started a project to reproduce a Dynamo HS-1 cabinet.
I found CNC plans here: https://www.classicarcadecabinets.com/hs-1-style.html
However, before sending the files to the CNC shop, I'd like to get a few more details.
If anyone has built this cabinet before, any information would be greatly appreciated.
I plan to have channels routed for each block so they fit perfectly into place. How deep should these channels be, and will that affect the size of the blocks?
- What type and thickness of wood should be used for the side panels?
- The monitor support seems to use a different wood type and thickness—can anyone confirm?
- Also, what are the exact dimensions of the various support blocks used to assemble the cabinet?
