The tag is long gone on this but you can clearly see it is black laminate plywood inside & out, not just painted. I have had a several like this. You can even see a black one in the flyers above where it shows the drawer! I believe the black ones I've had have all been HS9a.
When I restore Dynamos I strip them down to the laminate and try to refinish it, if it is too far gone I color match the paint so in my restore gallery the ones with black tops are probably all factory color.
This one also has the diagonal cut PSU hole, which is way less common.
Here are blue & black side by side I was working on a few years ago. You can see I'm stripping the black off the blue & grey cab. They look identical besides the color.
I've put 27" monitors in them before but never found one that way from the factory.
Right now I think I just have HS-5 and HS-8 cabs, but I'll start documenting tags when I find them.
Yeah the original diagonal elliptical cutout was a carry-over from the HS-5. At first i thought that the newer cutout supported AT style power supplies but it seems that isn't the case.
I really like those Dynamo HS9 clones like the red one you have there. The design seems way more simplified than Dynamos design. Would love to get my hands on one. I've only ever seen them for sale on the west coast tho. Seem to be plenty on the west coast auctions and west coast offerup.
I'm trying to get as many Dynamo ID numbers as possible and log them here:
Dynamo ID Numbers
Yes, I'm actually trying to compile a list of dynamo manufacturer ID numbers. Here is what i have so far. If you happen to have a Dynamo with an ID tag that is not listed, please post up your tag or your ID number. HS-2 Gen 3 Dowel 021200200 HS-5 Gen 1 Horizontal drawer 020800400 HS-5 Gen 2...
forums.arcade-museum.com
