Dynamo HS-5 Weight
Sandman2k16
LEXINGTON, Kentucky
I've seen the old flyer that shows the HS-5 weighs approx. 375 lbs, but is this correct? I've heard conflicting reports from owners - generally on the lower side (under 300 lbs).
With monitor, that sounds about right. Not the heaviest cab, mostly particleboard. With the monitor out it's manageable. I'm not the strongest and I can lay one down and pick it up.
