Dynamo HS-5 Control panel
wesk74
Toledo, Ohio
I have a Dynamo HS-5 cabinet that started life as a SF2:CE, and at some point was converted into a MK3. I am trying to restore it back to a Street Fighter 2 and have ran into a snag. The Dynamo Control panels are 1/8'' thick steel, whoever did the conversion cut a square the size of the entire button layout out of the steel, then put 1/2'' plexi down and drilled it to the MK layout. Can I Bondo two 5"X7" square holes, or will Bondo'ing a hole that big and thin be a bad idea? I plan on putting thin plexi back on top of the CPO to protect the new art. Do you think it will be strong enough? or should I try to find a new control panel that has not been cannibalized?
