Dynamo cut corner control panel overlay template?
OldTymeToys
Donor 3 years: 2011, 2013, 2018
Canonsburg, Pennsylvania
Before I go through laying out the Dynamo cut corner cp (HS-1 size) in Photoshop for my custom Heavy Barrel cpo- does anyone know if there is a cpo template out there already for these??
I looked around a bit when I restored my last game with one, but never found anything. I believe there are different size cut corner CPs (widths), so you may want to provide the width of yours. You can obviously edit what you get- just might save you a little time if someone can send you something even closer to what you have. Hopefully someone will provide you with one!
Yeah, a real template would be great. I'm considering getting some plexi cut from a nearby sign shop. In the meantime I've hand-traced some CPs and scanned those tracings. Haven't yet converted them to smooth vector files, but could be done (add that to the never-ending to-do list). Anyway, if this scan would be helpful, lemme know. I know it's prob not the best way to do it, but if it helps, I'm happy to share.
