Depends on how it's mounted. If it's the original one, there are 4 screws holding it in place on the back of the cab, and there are 2 or 3 molex connectors to unplug it. Another possibility is that the original died, and somone jammed some other power supply in there. If that's the case (depending on where it's mounted) you'll either have to slide out the front tray, or even remove it completely to get access to the cab. I've seen power supplies on the tray next to the logic board, or screwed to the back wall of the cabinet. Try that, and if you still can't get it, post some pics, that'll help, thanks.
