Dynamo cabinet: need to get dimensions for 25" Bezel
Snarly
New Jersey
Hi - bot a Dynamo cabinet with 25" monitor but it had no bezel or front glass.
Any one have the dimensions handy?
I am thinking of cutting the inside bezel from some plywood, and plexiglass for the outside....
Thanks,
Chris
Which Dynamo, HS5? Is the monitor vertically or horizontally mounted? I have an HS5 and can provide those measurements when I get home, if those are the ones you need.
Hi Oli,
I tried to make my own plexi monitor bezel cover....but what I got was too thin and spiderwebbed cracks all over when I put it in and then took it out...
I think the measurements should be around 27x28 - can you confirm?
Thanks,
Chris
1) top piece for mine was glass. Most are acrylic
2) the card board graphic bezel is under that.
3) a 1/2 particle board bezel is under that.
4) a black monitor bezel is under that.
5) the monitor is mounted to two pieces of wood that are screwed in by the two bolts on top.
I'd have to go measure mine to get you dimensions.
