R3LL1K
Hey fellas, hope someone here can offer up some advice on how to fix this issue. I'm helping a friend out who owns a Dynamo Air hocke table, the game works just fine except one side isn't registering the points whenever the puck drops on that side. I removed the metal protective plate and cleaned the opto hoping that would correct the problem but it didn't. When the plate is off the opto registers an object passing in front of it but with the cover on, it doesn't work. Any ideas on what the issue might be? I was thinking about replacing the opto board but the opto sensor is registering with the cover off so that can't be the issue can it?
