Yes... just rotate the whole monitor 90 degrees...
Things to take in to consideration though... will the monitor with frame fit in the cab in the direction you want to put it...often times horizontally mounted monitors "stick out" the back when turned vertically. There is no physical difference between a "vertical" monitor and a "horizontal" monitor. There ARE different frames though much of the time vertically oriented monitors are just horizontal framed monitors turned sideways.
