Dual Spec Ceramic Resistor - Help
djsolzs
Donor 2013, 2024
cincinnati, Ohio
Hoping you guys could help me find this...
200 Ohm 15watt on one side, 20 Ohm 5 watt on the other
Had some members in a different thread of mine suggest finding 2 separate ones and wiring them in series..
Anyone know where I can get one of these without having to wire 2 separate or do they just not make these any more?
Are all 3 contacts connected?
I have seen them in ovens, they are used to control the speed of the oven fan. Only 2 pins were connected.
The 2nd part of the resistor was never used, so when they burnt out we would use the 2nd resistor to keep it going until we ordered the part
Should be available somewhere
One piece and yes all 3 pins on the resistor are connected.. 200 ohm on one side 20 ohm on the other
Still cant find this thing... is it safe to assume that the opinion of the pro's on here would be for me to just piece 2 together and make my own?
