Frax
Pinbot was giving some switch errors on the middle and bottom left drop targets. I went under and checked them out, they're not MECHANICALLY failing as far as I can tell...they're normally open and fire when the ball hits them, or when triggering the microswitch directly...
Any other suggestions what I should be looking at? The error disappeared, but I think it's because I did a factory reset. I expect it to show up again in a week or so, even though they appear to be working.
Is it possible it's the microswitches themselves? I think it's pretty unlikely they've worn out enough to be intermittent, but at least it would be an easy fix if I can rule out other things. Didn't see any loose wires or bad solder joints, but it's on the side of the machine that's really hard to get to currently.. :|
