drop bank issues!!!!!!!!
Ok I replaced the stop, sleeve, coil, and the plunger. The damn thing is still struggling to come up!!!!!
Is it possible for the transistor to not be cutting on/off like it's supposed to even though it test good?
It sounds like there is too much resistance in the drop target assembly. I had the exact same issue with a 3 row drop target assembly in a Blackout. It would push them up when you'd lift the PF and make the assembly fight gravity less. I fixed it by cleaning the assembly really good and loosening the spring that pulls them down.
Not for LAH... The old williams horseshoe targets can benefit from a tiny drop of super lube, but you should be good on your game.
I think the "new" drop target springs are too tight as I have had this problem more than before on my games as well.
I want to thank Count for suggesting the springs because that was the issue.
Now other than cleaning/waxing, adjusting the pop bumpers to be more sensitive, and moving it the thing is done! Well until I find another playfield that's in much better shape!
