driver transistor help
Mr Do
Donor 6 years: 2012-2013, 2015-2016, 2019, 2025
Basking Ridge, New Jersey
Pulled a bad 2N6045 from a Baby-Pac.
Grabbed a F585-34 from a Bally Driver and got Baby-Pac working.
But I think NTE 263 = SE9302(which Baby-Pac schem says)
I think NTE 261 is 2N6045 which was in Baby-Pac but not correct according to schems
F585-34 I don't know which it crosses wit.
F585-34 equivilant is nte 263
So lets make sense of this
You pulled a 2n6045/NTE-261 (60vdc/ic5A)
Schematic stated Se9302/NTE-263. (100vdc/ic10A)
Replaced bad (2n6045) with a F585-34/NTE-263. (100vdc/ic10A)
So basically the transistor was under rated as per the specs, and you replaced it with an equivilant 100vdc/ic10A TO-220 NPN transistor that it should have had in that location, with a working pull off a bally board.
You also could have used a TIP 102 (100v/8A) this is what marco specialties recommends for the Se9302 equivilant replacement.
Does this help?
