I had a meeting last night, and didn't get a chance to turn on a video game, much less hook a DMM to BZ. I'll try again tonight...
No problem being a novice with the 'scope. None of us were born knowing how to use one. A general guide is here:
http://www.doctronics.co.uk/scope.htm Every scope is a little different, but most have plenty of similarities. To use it as a vector monitor, you'll need to figure out how to put it into "X-Y" mode, where the horizontal position doesn't move at a specified rate (as it normally does; selectable ms per division), but it is instead controlled by the 2nd channel input. On mine, it's at one end of the dial for selecting sweep speed. Some scopes apparetly have a button to enable X-Y mode. Set the other dials to maybe 2 or 5V/div for starters. Switch the coupling to GND, center your beam, then switch each channel to "DC" coupling.
If not getting any video output, I'd want to first verify that the digital (MPU) portion of the board is running before diving into the output DACs and amps. Of course, if it "plays blind" then it IS running, and I'd agree with your approach of looking at the video output bits. If it's not playing blind, or if it's "watchdogging" constantly, then there may be no real expectation of video output. "Watchdogging" is a feature Atari built into the game, whereby if something goes wrong and the code goes off the tracks, the game will reset rather than "hang." This game code is written such that a particular "address" is written to periodically (many times a second, actually). A hardware counter gets restarted each time this happens. If a certain period of time elapses without this particular "address" being written to, it resets the CPU chip (rebooting the game). It's pretty easy to tell when an Asteroids is constantly watchdogging, because the LEDs in the start buttons blink a couple times a second. I'm not sure of an easy way with BZ. Personally, I'd stick a logic probe on the reset pin of the 6502 and see if it's pulsing or not. (Not sure if you have a logic probe... your scope can also be used to check this, once you get up to speed using it.) In any case, my advise is to ensure that the game is running before worrying about video output.
If you're near NE Florida, I can give you a break and come over to crimp on some of those split pins for ya
