The 1000 is dead. Opens to remove the disc but nothing else. The game boots to 00 on the credit LEDs. The monitor works fine, I fed it from an 8000 and the disc played fine.That thing was a mess on the outside, but MAN it's beautiful on the inside.
I wonder if the LD-V1000 still works?
You will need to change the EPROM set. You have Rev-D which was the switch over from PR-7820 to LD-V1000.
The problem is that they changed the Real-Time-Clock hardware, but kept the old programmed timings for the earlier board.
The end result is that the video for all of the rooms either run too long, or get cut short (I can't remember which).
Anyway, Great Score! Now what are you going to do with all of that other junk?
Some more pics from the interior:
