You really need to specify if you are looking for the Wells Gardner or Electrohome brackets. From my recollection, there are different hole spacing on the cabinet so one would not line up with the other.
Mike is correct. Their are 2 different sets of brackets. The most common is the short brackets and then you have the long brackets. The short brackets have been reproduced before but no one has made the longer ones that I know of. My cabinet had the long brackets so I got some angle stock at Lowe's, the kind with all the holes made in it and made some. You can see the one's I made here. http://members.cox.net/severlander/Sams_Dragons_Lair_project.html
Hope this helps
Sam
in Virginia http://members.cox.net/severlander/index.html
