I don't have one of the conversion harnesses but someday plain on building a Space Ace so I have saved some info on what is needed. I believe the conversion kit came with a short extension harness with 36 pin Molex plugs in each end. This would go between the Dragons Lair main board and the original wiring harness. This would have 3 wires coming off it with a 3 pin Molex plug that would plug into the annunciator board. Then their is another harness with a 9 pin Molex plug that plugs into the annunciator board and goes to the Skill level select buttons. Their is also a ribbon cable so you can plug the annunciator board between the main PC board and the score board. I think that's all. If you don't have the 36 pin pigtail harness you can add 3 pins in the original 36 pin Molex in the game harness. Here is the info I saved which I think I found on the Dragons lair project.
If you cant find one you can just add the 3 pins into the original 36 pin housing. They are .063 pins, just put 3 pins on 3 wires and push into the 36 pin connector at pin 17,21 & 25 and run them to the 3 pin plug on the annunciator board . I found this info on the Dragon's Lair Projects Archives
http://www.d-l-p.com/community/foru...essageID=49137&Archive=Yes&Keywords=space+ace
Text with info
On A DL/SA conversion harness, The connections
for the Skill Level Buttons go to a 3 pin
connector which connects from pins 17,21,& 25
on the 36 pin molex plug on the harness to the
SA annunciator board. There is another small set of
wires going from the 9 pin connection on the conversion
annunciator board to the Skill level select buttons.The
scoreboard ribbon cable also goes from the main pcb to
the annunciator board and then an additional ribbon
cable connects from the annunciator board too the led
scoreboard.On a dedicated Space Ace Wiring harness,
the control panel connector has 12 pins instead of the
typical 9 pin connector. Hope this helps.
