Dragon's Lair II - PCB woes.
KI4SWY
Donor 5 years: 2013, 2020-2023
Brandon, Florida
OK, so, No CLK @ CPU, but if Reset it pushed, clock shows up, if i remove cpu, clock shows up, otherwise no clk signal.. which comes direct from the 82C100... (the 30mhz and 14.~ clock signals are present).
the Watchdog LED turns off when voltage drops below 4.6v so that circuit is working.
i looked at everything else possible, and can't really find anything wrong (not like there is a ton of logic on this board), schematics are horrible, can't find anything on the 82C100 smt controller/brain/i/o chip (basically the other half of the XT computer)...
this board appears just to be an XT computer with some I/O and a Serial Port...
Anybody got any ideas?
