Dragon's Lair bezel measurements
OzTron
QLD, Australia
Can someone measure me the size of a plastic bezel both the outer and inner sizes please
No problem!! What do you mean monitor part?
Well the measurements where the monitor is. I need to know the outside measurements that sit on the frame for the monitor and then also the inside of it (where you see the screen) I'll see if I can find a photo and mark out what I mean
Yes post a pic.
I hope the attached helps :D
So I need the outer arrows width and height. then the inner arrows width and height.
And if you have time, the measurement of the drop to the monitor and also the measurement around the outside to the drop of the lip. Say 2 inch then drop of say 1 inch (if you get what I mean)
Just to verify, do you want the measurements of the total frame? The top part tucks in under the score board unit.
I have mine exposed right now and can also grab the measurements once I get home tonight. The front edge under the control panel is also bevelled and the total thickness of the wood would be about 1.5" on the sides (they stapled 2 3/4" boards together) - the frame is not actually 1 piece but (IIRC) 6 pieces in all. ;)
If yours is already exposed go for it!! Then I dont need to take mine apart:)
I will wait until tonight to see if you still need the measurements from me:D
Just the plastic shroud is all I need, I have the 'wood' part, I need to know how much of the plastic is on the wood and is the 'hole' right for a 21" monitor, but I'd like measurements so I can be spot on for my repros
Hi - ok the inside measurement is:
Wide - 15 3/16"
Tall - 12 3/16"
At the top of the bevel
Wide - 17"
Tall - 13 3/4"
add 2" to the top of bevel measurement for the outside edge of the mask, but I also have another mask that is wider by another 2".
If you are going to use a 21" tube - is there not a 21" mask available?
Wide - 15 3/16"
Tall - 12 3/16"
Wide - 17"
Tall - 13 3/4"
Kudos mate :D
Thanks heaps for that
