how much are you looking for it?
There are two "pressings" of the DL2 disc.
This is the first pressing, indicated by the 00001 in the serial number.
This disc is only for use in a true DL2 machine with proper ROMs.
If you're looking for a DL2 disc to use with Merlin in a DL1 machine, then you will need the second pressing (00002).
Interesting. I was not aware of this tidbit of laser lore. Thanks as always for the guru info, Shaun.
What's the technical difference between the pressings?
