Double Dragon ground bar replacement
bustedstr8
Stoughton, Massachusetts
The paper covered ground bar on my pcb is broken off in numerous places.
Why would they use something like this....does it act like a heat sink or something?
I haven't powered the board on yet and wanted to know if I can just conect the
ground points with 24ga wire or do I need something similar to that bar.
It is hard to picture from what you said.
Can you post a pic of the problem?
You can usually ground in a place or two but I really would like to see what you got before you do ANYTHING.
This paper covered bar is connected to the pcb in about a dozen places.
