GoneMad
- Joined
- Mar 15, 2011
- Messages
- 1,347
- Reaction score
- 36
I've been wondering why my double dragon is not booting up. So normally you start with the voltage. Everything seems OK at the PS so I get a couple pinout sheets of the net, both are the same so I grab my multimeter and start to check voltage at the edge connector. Pin 1 and 2 both ground. And so on.. then I get to pin 6 to check the +12v and,,hold on a sec, there is no wire on pin 6! There is on the solder side but not the part side. If the schematic shows +12v should be on pin 6 of both solder and part side, there should be, right? Noticed a couple other wires a little mixed as well.
