Double donkey kong pcb with d2k +double dk remix kit possible?
Brian Kirby
regina, saskatchewan, Canada
Is it possible to install a double donkey kong remix kit as well as the d2k chip upgrade on an existing double donkey kong (dk jr braze kit) pcb?
i have read about people stacking the daughter cards but it is usually on a dk pcb without the double donkey kong on junior pcb.
Adding commentary, I looked it up, and I don't think so since a ddk is done on a Dkjr, and dkII is on a dk board. I believe you can combine a dk remix and dkII on the same board.
The only real issue is whether the "copy protection" in the GAL is different between the kits...
DDK is (mostly) unmodified DK code running on JR... DK2 and the other mods should run on DKJR boards as well.
