Double Donkey Kong BOARD FK UP!!! HELP!!!
wmacmonagle
Donor 2012
Rosamond, California
Yes I know POIDH! I need to take picture tonight and shoot you guys the concept what is the issue.
When I powers them up and It powers up just fine but only thing is....
Picture shows right half perfect but left half bad wave.. VERY CURVE Horizonal from edge to perfect half of screen.
Yes I got spooked if it was monitor. I decided to swap gameboard and WHEWWWW other gameboard shows perfect screen.
It s DOUBLE DK board issue. ANybody experience this problem before? I had double check and re seat everythign and still get same result? It is currently attached to the L mount with metal bracket from side to other side.
Any 2 cent would be appreciated. I have plenty coin jars to collect! This will be passed out to others when Im there in your expert class =)
Very common problem, adjust VR451 H hold on the monitor chassis about 2" toward the tube away from the flyback. No need to replace any caps at all.
i removed double dk board and replaced to different gameboard.. its perfect. This tells me it s gameboard. I m going to test with this board in other sanyo ez 20 to see the result ..
Double dk was working fine until now.
will update in few
Sanyo dokert did it again!!!!
swapped double dk into vs cabinet and tested. wow it s perfect. I decided to take Expert Dokert s advise.
There goes again He s right!.
MY DOUBLE DK WORKS PERFECT >> THANKS TO DOKERT!!!!
will update in few
you forgot to include wmac in the title!
j/k
honestly, what's the significance behind doing that, for thread search purposes?
