FS Parts: Dot Matrix Display works-$35 TNT AMUSEMENTS
Todd Tuckey
Donor 2019
Southampton, Pennsylvania
I have a working display...not perfect, but ideal for that auction special or a game you rarely use...and its priced right! This works fine on all brands EXCEPT Gottlieb--which run their displays at lower voltage to prolong life---but there will be more missing dots if you use on a Gottlieb!
Look at the video: http://www.youtube.com/watch?v=95i7vZy_u6o&feature=youtu.be
email me directly [email protected] its $35 plus $11 flat rate Priority mail .. Todd from TNT
I'd bet the display is fine, except the one line out.. Flickering is almost always the DMD high voltage pcb which is in need of a rebuild. Even that one line can be fixed if you research a bit.. I've done it.
Great price!
no...its definately the display...we always install new filter caps and resistors on the power supplies...and that did not fix it...we simply installed another display! But you are right... in some cases this could solve the problem for others! Todd
