Zud
I have a HS Getaway that is having issues with the display.
All the lights are good and work, but during the gameplay and attract mode the display does not always display the correct lights.
While I can still play the game, it does make it hard to see your score and play the video mode part.
What is required to get this corrected? My initial thought is to pull and clean any of the chips on the boards. I did check for loose connections and that is not the issue. I have attached one picture that shows the issue. Now it is not always a vertical line, but shows that there are lights lit that should not be.
